Any decent brand of green antifreeze properly mixed would be acceptable. Personally I usally run shell. Always had good results at a good price but as long as out is properly rated for temperature protection fot where you live you should be fine.
getting the coolant to drain is usually the problem. my tractors are so old , every thing is rusted.
last time, i loosened lower hose and wiggled an ice pick beneath the hose and let it drain. lol
(quoted from post at 21:45:57 11/14/14) and how much
Capacity is listed as approximately 9 3/4 quarts. If you do your own mixing, premix it first before filling. Don't mix it in the radiator due to the thermosyphon system.
