Super H hydraulic oil fill
Mtractor
I have a Super H with the live pump where do you ad hydraulic oil? I have found the dip stick under the plug to check it.
Ones IH built with a engine driven pump didn't have a dipstick. If you have a ad on pump that's using the unit in the center housing as a reservoir you would check and fill under the cap where the dipstick is. Unless someone plumbed another reservoir in as a overflow for the center housing unit.
Thanks mine must have been added . No other tank is there. Does the whole plug come out ? When I remove the cap all I see is the dipstick and it has a small hole.
Original full level with a 3-1/4 inch long 3/4 inch pipe nipple screwed in the unit was 9.5 inches down from the top with the cap off the nipple.
