Farmall H upper bolster shaft
My parts book shows 3 different pivot shafts depending on serial#. Early is 50039DC/67837DB. Middle ser# is 67835DB/69062D. Late ser# is 69060D. The aftermarket shafts show to fit this later number. Will they also fit early & middle too or what is the difference between these 3? Thanks
All the replacement shafts were 69060D.
Early replacement package 67837DB contained spacer 67836D, felt retainer 68963D, felt 350000R1, thrust bearing 354676R91 and the 69060 shaft. Middle package 69062D included 68963D. 350000R1 and 96060.
The earlier shafts were cut for a round keyway for the cultivator steering arm. The later shafts/arms used a woodruff key.
AG
I still have a couple left, I never noticed if they were different or not and now I will have to look. I just had assumed they were all the same.
Zach
