I use this for clearing snow at a cabin in Wisconsin. The loader and tractor are working fine. The loader twists very easily and quite a bit when lifting an unbalanced load or even setting down to latch bucket. It does however follow the uneven ground well like this.
Should I use it like this?
Will it cause metal fatigue?
Should a add bracing to loader?
Should I add a hydraulic valve fitting thing to lines to equalize oil volume?
carpenter
carpenter
