I have a loader on the tractor and yesterday had a lower toned howling noise coming from the valve control area below the dash. The loader controls and the two point hitch control work fine. The howl gets louder with higher rmps. My pressure relief valve normally has a hissing noise when the engine is running and stops making the hissing noise when using a hydraulic valve. The howling started as an intermittent sound about a month ago and would go away at low rmps, but is constant now. I haven't changed any settings on the tractor and have two way hydraulic power for the loader like usual. Any ideas on what to check or how to fix? My power steering works and I added hytran this summer.
