IH 856 and chisel size
MJordal
New User
Does a IH 856 have enough muscle to pull one of the smaller 7 or 9 shank brillion or similar disk chisels with twisted points? The tractor does not have the M&W turbo setup. If the 856 won't, what size tractor would? We have been hiring a neighbor with his new magnum and disk/ripper to do the fall field work for several years, but this year he might not get to us. Thanks in advance.
I pull a 9 shank CaseIH 6500 disc chisel with my 1456, and many years that is all she wants and my 1456 is turned up to 150hp.
Not sure how it compares to what you're describing. But I pull an 11 shank Graham Hoeme with 4" twisted behind an 806. Does fine in 3rd at about 6 inches deep.
mjordal, I have a 966 that I pull a 13 shank 3pt chisel with regular point 8 inches deep in med ium clay loam/calachie based soil here in Central Texas. I also pull a 13 shanks drag type Graham-Hoeme with sweeps at slight shallower depth too. The 4in twisted shanks might require a few more pony's but an 856 will/should handle it unless you are in a heavy clay based soils!
Later,
John A.
And 856 with a M&W hair dryer is probably turning 115-120 horse and a seven shank with 4 inch twisted shovels will work well as long as you have a full rack of ft. weights loaded tires and duals . one other thing is tire size , if it has 18.4 x 38's or is it down on 18.4 x34's . You should be able to run first high in descent ground around 8-10 inches deep. My 806 will run a 9 shank straight shovel eight to ten inches deep but it is a three point . We are now DEEP ripping with a barn yard engineered Land Doll disc chisel that now had five DMI parabolic Tiger shanks with seven a half inch Tiger points and five or six inch upper shank shovels and going down thirteen inches or in other words five to six inches into the clay behind a 1066 that is tweaked and weighs in at around 18500 . now normally we can run first high , but Wednesday was not the case as i was ripping one ten acre field that we had chopped corn on when it was to wet in the rain and the wagon tracks in places would take you from 6-7 MPH to 0 in the blink of and eye . I had the pony power but was lacking traction and weight even with the duals .
Depends on your soil type. Around here 150 drawbar horsepower FWA tractor can be stopped with a 9 shank chisel. Usually we try to run about 7 to 8 inches deep. Tractor won't pull it worth a darn in 2wd. I would be looking more in the 5-7 shank range.
