Anonymous-0
Super C. I just finished a complete overhaul, sleeves and all,
about two weeks ago. Its been running good for the first three
hours or so of run time. Today a high pitched squeal developed
and sounds like it is coming from the very front, up around the
accessory belt. After a couple of minutes of run time, just to get
back to the shed, it starts smoking a bit up front. I have lube in
the fan assembly. Is there anything that you guys have dealt
with that sounds obvious? Alternator or water pump pulley
bearings? I havent had time to look because i had to get the
little goblins ready for tonight.
Joshua
Joshua
