When I bought my Loboy 184 a few weeks ago it cranked over fine from the switch. The it got to where it wouldn't start from the switch but cranked over fine by running a jumper cable from the batter straight to the starter so because of that I'm assuming the battery is OK. When I turn the key the starter solenoid just clicks like a lot battery. Checked it out tonight with a volt meter and I only have 6 volts coming from the switch to the solenoid. Its a 12 v system and have 12 volts at the wire going to the switch.Can a bad ignition switch drop the voltage that much. I don't find a voltage drop anywhere else I check. It does have a safety switch on the clutch but when the clutch is not depressed there is no voltage as one would expect.
