Ih 1566 outer rear axle wheel seal
gillet598
My 1566 is leaking hyd fluid out of outer seal. Can outer bearing and oil seals be replaced from end plate or does the whole housing need to be removed?
Thanks Dan
(quoted from post at 22:46:08 10/28/14) My 1566 is leaking hyd fluid out of outer seal. Can outer bearing and oil seals be replaced from end plate or does the whole housing need to be removed?
Thanks Dan
The seal can be replaced from the outside.
Replacing the bearings requires axle removal.
Requires a bridge and porta power to disassemble the axle.
A porta power and press sleeve are used to set the rolling torque.
