coil core for H4 magneto
tractorguy2
I bought a nice H4 mag turned out to be missing the coil. I bought a new coil but am having trouble making or finding the iron core.
Anyone know where I can find the center iron core for the coil?
to the best of my knowledge, they are not being made anymore. your best bet is to buy a used one from a mag shop or salvage one from a junker mag.
Part # was 21314DX. Subs to #21314D at darned near $600.00 from FIAT.
If you can't find one, I will sell you a good used one for $10 plus mailing.
Contact me, if you'd like... big [email protected]
John, good to know about brillman. Yes, these are laminated, although I do wonder how a cast iron rod would work. Not a difficult task to turn one on the lathe.
(quoted from post at 10:43:05 10/28/14)I do wonder how a cast iron rod would work.
robably not that well. Most transformers (which is what a magneto is) have laminated cores to keep current from being induced through the core. A solid core would probably bleed off some of the generated power, yielding a weaker spark.
Generator and starter armatures are laminated for the same reason.
(quoted from post at 17:24:28 10/28/14) FYI, John M, check out the link below.
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/IH/H4a_zps24e5cb12.jpg">
Previous thread
The core I've had out didn't have the rivets showing. Did IH make some with counter sunk rivets?
well, one thing for sure, whenever I come upon a junk mag with the coil inside, I cannibalize the parts, and for sure, keep the core (if it is salvageable).
I have a couple on the shelf that I keep for rebuilds. If I had more than a couple, I would certainly sell them, but I don't. Sorry about that.
Naw, they're just riveted really tight, then ground smooth. You don't notice the laminations or rivets unless they get beat up.
