farmall 200 compression check
dewy
whats normal compression....one tractor has 120 an the other 150 lbs...just curious.....dewy.....thanks yall.......
Comparing two tractors must be done carefully. Temperature, battery condition, cables, throttle open on one not the other, amount of wear, prior upgrades to pistons/displacement, and using the same gauge in the same manor (number of compression strokes etc.) both numbers are OK, one pretty stock, the other a bit "improved". Jim
To give you an example my 200 is within 3# of 150 on each cylinder. 12volt with a big cranking amp battery and a newish starter.
Clint
