Bd154 sleeve seals
Phil Tibbetts
We are finally getting around to replacing the seal on the sleeve in my 364. Question is do the o-rings come with a gasket set or do you need to order them separate? Another question what do you experts think of using a little Permatex Aviation cement on the seal? I have used it before with problem o-rings with good success but don't know how it would work in this application.
