bassmasta76
Hi,
I need some help on fixing the throttle linkage on my H. The attached pictures show the current state, and I was hoping someone could provide a picture or two of what it should look like. It "works" now, but not very well, as it either binds or doesnt adjust properly.
Any suggestions on a good fix to tighten things up would be helpful. The pivot point where the governor control bellcrank meets the bracket on the head isnt very tight which has probably been a problem for a long time since the governor control rod has worn out the hole in the guide plate where the gauges mount..
the below pics are what it looks like now.
thanks in advance for any advice!
--b
--b
