super c rear axle leaking
bass
where can in find the oil seal, felt washer, and gasket for a sc rear axle? mine is leaking where the axle comes out of the housing
When I did mine last winter I got all my seals and gaskets at the Case IH dealer. Mine was leaking in the same place as yours but it turned out the bad seal was where the axle comes out of the transmission and it was running down to where the axel exits the housing. So I had to seal both ends.
Yes you can get all of the parts from Case/IH. The felt seal will have to come from there. The gasket can be replaced with grey RTV. The oil seal will cost you at least twice as much from Case/IH compared to other sources. All Case/IH does is re-box other manufacturers seals. I would start by looking on this website for the seals. If they don't carry them then I would go to the Case/IH web site and look up the Case/IH part numbers. Do a cross reference to National or SKF and buy it from an auto parts store or an industrial supply near you. I bought seals for my first H from Case/IH and I think I paid like $26 for one axle seal, I screwed one up and called my local auto parts store and found the same seal for like $16.
