6v light switch
bass
im running a sc with a 6v system with an 8v battery. do i need to replace the 6v light switch with a 12v lightswitch. im swtching the 1133 bulbs to 1143 but what about the switch?
"do i need to replace the 6v light switch with a 12v lightswitch"
NOPE, the switches voltage withstand rating is much higher then 6 or 12 volts, anyway so as long as the switches current rating is okay (most likely is) it will work on 6 or 12 volts.
Also if the total wattage of lights was the same, if you're now running at 12 volts the current draw through the switch is less which is even better i.e. again no need to switch.
John T
You are fine on the original bulbs, the new ones will be too dim. The voltage regulator will need cranked up if you have one.
