656 Axle and Wheels
1 Dollar
I'm looking into putting some taller/narrower tires on my 656 for some narrow-row in-crop spraying jobs. It is a 656 hi-clear utility with 16.9-34 tires right now. Something like a 12.4-38 is what I'm looking to swap on for spraying jobs.
If I read this right, the M and 656 have the same axle size? So M wheels could be put on a 656?
If not, what are my options?
Thanks
For double bevel rims tractors that used a 2.75 axle work. 400,450,560 some 460 and others. If the axle has two keyways a M would bolt on. If one keyway not without grinding the clamp casting part that goes in the keyway off on a M, wouldn't recommend it. Later IH made some M wheels and clamps for M tractors that used two clamps and one key in the wheel but you don't find them everywhere.
