super c lighting
bass
question! at the end of the light bar where the wire comes out to the headlight is there a rubber grommet there to keep the wire from rubbing?
(quoted from post at 02:14:49 10/20/14) question! at the end of the light bar where the wire comes out to the headlight is there a rubber grommet there to keep the wire from rubbing?
You can slit a piece of vacuum hose and slip over the wire or remove the connector and slip the hose over the wire, then use a new connector...I've done this many times, works great....
