I bought a Lowboy 184 this fall and when I bought it it all turned over and started fine. Now I can't get the starter to turn with the key but if I jump from the battery to the starter it turns over and starts right up so I know the problem is from the switch to the starter. I got it apart and don't get a voltage reading from the switch to the solenoid but at this point I'm not sure I have power to the switch. I ran a wire from the battery to the starter solenoid and all I got was a click like you get with a dead battery. Battery is fine as I said a jumper cable turns the starter with no problem. Does getting a click sound when jumped like that mean the solenoid is bad. I think I may have some other problems as well, possibly with the switch. I'm trying to get this thing figured out so I can order some parts today.
