Help Identifying
Pete_5959
Can someone help with the model of this tractor. Thank you.
F-12 , They were the only F-series that had adjustable rear tread width by sliding rear wheels out on exposed axle shafts. F-12 and F-14 are like this .
Appears to be an F-12 or F-14 with some altercations. It is not an F-20, listed as a possibility below. Frame rails and engine don't look right. Probly from something else.
F12 with a non-IHC flathead engine swap.
Most likely the engine is a Continental F163 (will have the distributor perched on top of the head between the #2 and #3 cylinders).
