jsr8011
Took hood off to adjust timing. When finished, tried to put it back on and alignment is off. I'm guessing I moved the radiator when trying to turn the fan blades lining up timing marks. Does this sound right?
The radiator is spring mounted at the bottom. But
it should have a brace at the top. Either direct
to the top of the block or newer models had a rod
running back to the steering / read hood support.
Sometimes it makes a difference which side of the
hook you cinch down first. Keep messing with it.
It should go back the way it was.
