CUB Decal +ground-firing order
My newly aquired, one owner 1951 CUB has a decal located on the hydraulic pump- right side, which got wet in the rain, but states that the charging system was +ground and the engine firing oorder is..... Is this a factory decal ?
(quoted from post at 18:57:04 10/15/14) My newly aquired, one owner 1951 CUB has a decal located on the hydraulic pump- right side, which got wet in the rain, but states that the charging system was +ground and the engine firing oorder is..... Is this a factory decal ?
Also, that isn't the hydraulic pump. That is the "Touch Control" hydraulic resivoir which houses the piston and control valves. If you follow the hydraulic lines from the TC Resivior, you'll find the hydraulic pump on the engine block. It is squarish and made of aluminum.
Firing order is cast into the engine block or cylinder head (forgot which).
Do not recall any decal about + ground.
Do you have an owner's manual? Essential need for any tractor owner.
