super C wiring
bass
Hello. Im new to the forum so here is my first question:
looking for a 6v, pos ground wiring diagram for my SC. its a 53 model. im not new to farmalls just a little short on wiring
The owner's manual includes a wiring diagram, so it may be time to invest in one.
You can also look up "Bob M's Wiring Diagrams" on google. Bob M, a member here, has drawn up a series of easy-to-follow wiring diagrams for the various possible wiring schemes on letter series tractors. Keep in mind just because it says H or M does not mean it does not apply to your C. They are the same.
As noted by mkirsch the wiring is very simple and basically the same on all the letter series gasoline Farmall models. The key in having a useable 6 volt system is everything, battery, generator, voltage regulator and battery cables in good condition. For the battery cables use 00 cable with soldered terminals and all connections must be bright and clean. I use a battery maintainer on my 6 volt tractors when not being used for extended periods and the batteries seem to maintain a very useable life, Hal.
(quoted from post at 01:32:09 10/16/14) This will do it. Jim The real site is here (sorry)
http://s101.photobucket.com/user/farmallbob/library/Farmall%20Tractor%20Wiring%20Diagrams?sort=4&page=1
