international 300 utility hydraulic power beyond
holmsey2012
New User
I recently bought a ih 300 utility with a loader on it. It all works but I believe there is a better way. The hydraulics for the loader is taken off what I believe to be for the remote hydraulics. Problem being to operate the loader you have to move the remote lever (rt side front lever) and when that is activated you lose power steering. Is there a separate power beyond that could be used? Thank you for your help.[/b]
There is an issue with the system. It is probably the Regulator Pilot valve that is staying open. Or the way it is plumbed is taking power from the system before the pilot valve and priority valve. A good way to have a nice fast Loader is to put a crank driven pump on the front bolster. Jim
