I went to mount a post hole auger on my 300U and found that the fast hitch with straight adapters is not wide enough for the auger frame. Didn't take a measurement, but the auger frame was probably about 3 inches wider than what would fit between the adapters.
Has anyone designed any fast hitch adapters with an offset to fit wider 3-point implements? Any pictures/descriptions would be helpful.
My fast hitch setup is the right width for a fast hitch drawbar to fit in correctly and, with adapters, has worked for other 3-point implements: rotary mower, blade, etc.
