Hey guy, I need your advice on a 706 gas tractor. My neighbor has one with a cab, wide front end starts and run good like new rubber, and a fast hitch. No air or heater. TA is good. Cab is good with no glass broken out. He"s asking 3,000. I know it is a good buy, but will I be able to sell it later? What is this gas tractor worth. I of course would rather have a diesel, but beggars can"t be choosers. Any info would be helpful. Thanks
Its probably worth 3,000 bucks. I would bite on it if everything is is up to snuff. What will you be using it for?
We've got a 706 gas (engine is seized now, going to open it up this winter hopefully). I spent a lot of hours on that tractor. Ours seized from a failed radiator and it overheated before we noticed. Aside from that, it was a great tractor. 3k for a running example is pretty decent. You know all the usual stuff. If it still has the original shifters, the linkage needs to stay adjusted to keep from damaging the linkage. If it's really loose and hard to find gears, it needs to be adjusted.
