1026 loader hydraulics
lti
Is there any type of valve that a person can couple in between the loader cylinders and the couplers on the tractor to keep them in one place.Its been years ago but I seem to remember something in that area was mentioned at the local IH dealership. We have valve problems but trying to get buy until we can rebuild the valve. Have some oil seeping from under the seat and it does it on the other circut also The clinders arent seeping rebuilt one about a month ago.Thanks
You could use a pilot operated double acting check valve. They were an option for the hydraulics on the tractor. If you use one you will have to use the hydraulics to lower the loader. It will no longer go down if you move the valve lever without the engine running.
Double acting check valve
