My left brake is very touchy on my F300. I removed the drum and cleaned everything including the ramps and balls. This improved it to the point that I can use it without locking up but it still is too touchy for much use. When I press the pedal you can hear a click from the drum area like the expanders are hitting their stops on the drum. Would replacing the discs help this? They do not look very worn and I replaced them about 6 years ago with not too much use on them. If the drum needs to be turned how much should I tell the shop to take off the mounting surface?
Much appreciated!
Much appreciated!
