Farmall M rims on H cast centers?
PretendFarmer
I have an opportunity to get what could be a good set of 13.6-38 tires. They are older and somewhat hard which I think is good for pulling.
Right now I have 11.2-38's on. I'm getting beat by bigger tires.
Can I mount M rims on my H cast centers so I can properly run the bigger tires?
Edit; my H has a factory low gear so turning the bigger tires isn't a concern.
(quoted from post at 13:21:52 09/30/14) I have an opportunity to get what could be a good set of 13.6-38 tires. They are older and somewhat hard which I think is good for pulling.
Yes, the rims will interchange.
I agree with rustyfarmall. I am pretty sure the rims can interchange, and I know the caste iron centers won't. Axle diameter is different is why the entire wheel won't interchange.
Agreeing with all,YES, as long as they are DROP CENTER
rims off of am M/SM gong on an H center and not double
bevel rims off of a 300/350 400/450 .
(Gotta know this because alot of wheel centers and rims
have been swapped over the years. ;)
