I have a late model 684 with a Laurin cab fitted and I have been trying to find an air filter for the cab without success. The filter is located at the rear of the tractor above the rear window (in the normal place) and measures 28" long, 7.5" wide, and 2.25" deep. It has a metal frame and a metal mesh on the bottom side. There is also a tab on each end that the cab brackets clamp on to hold it in place. I don't see any numbers on it.
These cabs were fairly popular in Canada during the 70-80s so I'm hoping that someone here can point me in the right direction. I also have a couple broken windows but will likely just make drawings of them and get some safety glass cut at a window shop.
The tractor works great so now I'm trying to repair some of the creature comforts like the filter, radio, etc. Thanks for any help that you can provide.
