Anonymous-0
Last thing to do before starting after my overhaul is getting the
distributor installed. So to line up the timing marks under the
clutch housing i was going to tap the starter a few times and
look for the marks. Tapped once, crank revolved a few degrees
and now wont crank at all. Starter is working, and i turned the
motor over many times when it was out of the tractor. Did i
install the clutch wrong? What would be causing this? I am
hoping that the tractor doesnt have to be split again.
Joshua
Joshua
