Plugs for 460/C-221 Engine
Hey guys! Wondering what you guys like for plugs in your C-221 engines? Its in a 606 utility but is the same engine as used in a 460. It has Motorcraft plugs in it now, and I was going to use Autolite 386 but thought I'd see if there was a better option. Will have fairly light use...loader work, plowing snow, building fence, maybe running a bush hog.
Also, any tips or things to watch for with this engine? Thanks!!
3116 will work, but is a non-resistor type which might cause static and interferance with A.M. radios and/or television reception. The 386 would be a good choice.
