IH C lift box leaking?
Geo-TH,In
I removed the leaking control rod form lift box. There was only one o-ring on rod, however there are 3 other groves without o-rings. Is this normal?
I had removed the box once before, but somehow it gained weight, is this normal too?
thanks
George
I believe BOTH are perfectly normal.
That O ring is a common wear item on a heavily used touch control. Replaced several of them myself.
I replaced the left side control valve oring on my Super C last summer and I think that's the only one on the spool. I didn't take the box off though, I took the rockshaft bolts out and blocked it out of the way just enough. That seal's going to cost you 6 or 8 bucks from the dealer for a fat o ring.
You can still get a complete seal kit for the entire unit from Case IH. It will run you just over $100.00. I did mine last year because I figured if it was out of the tractor might as well go thru it. They also have a manual for just the touch control. If I remember correctly there is just one o-ring.
