H water pump drive pin
riverbend
I'm adding a new piece of packing to the water pump shaft and can't turn a wrench on the packing nut. The drive pins and a stamped ridge on the front of the fan are in the way. Plan is to remove the water pump driver, except the pin won't come out. Ideas ?
Thanks
Greg
The pin is tapered so it wedges pretty tight. You need to support the back side of driver with a hammer, bar or what ever you can hold against it and then tap threaded end of pin.
