Super M belt pulley gearbox.
As noted, it was designed for reliable use at rated HP. if you tweak the engine to the output od a 450 I think you are still safe. they tested at about 55HP. Jim
Well the gearbox is the same that would have been used on a 560 or 660 isn't it? I'm wondering if you can put 90 or so HP through it.
