farmall 200 brake shaft seals
dewy
can they be removed externally,when replacing brakes....are they a pain or easy....thanks....dewy
Easy to do. Locate the small indentations and use a small pry tool to remove the backing plate & seal.
There is a large o-ring that should be replaced at the same time.
thanks wayne .thats what i want to here...recently got 200 pretty rough ...gonna need seals...dewy
