5250 Three Point not working.
Nick U
New User
We have a 5250 CIH Maxxum that has 3 point issues. The 3 pt will move with the right fender buttons but will not move on the left fender buttons nor the rocker switch in the cab. The rocker switch in the cab is new. Thank You for any suggestions on where to start.
Will it work correctly with the lever? If it does I would suspect a bad controller or a wiring fault. Check your grounds. These tractors are famous for electrical gremlins. Find a factory service manual and start tracing wires. Good Luck!
