Super C Starter Contact
Yes, but the heavy copper field coil leads need to be soldered to it without burning up the insulating washers between the stud and the starter "belly".
This is best done with a large "soldering copper" by someone who has had some practice previously.
I don't think TSC has it, you need an old fashion mom n pop real starter repair shop...Id get a new switch while at it as it has a new good copper contactor to mate with that starter post.
John T
I recently installed one and got it at CaseIH dealer. Had to order it of course. I use a torch to heat it but you have to do it at an angle across the face of the new stud so as not to harm the insulators. I always remove the field coils so I can clean the ends really good and I put in new phillips head screws in pole shoes as they are easy to tighten with an impact tool(the one you hit with a hammer). Also, note that the pole shoes are directional and I always mark them and put them back in same location as removed.
