Looking for plugs and plug wires for an M
R Weld
I am replacing the plugs and plug wires on my M. What and where should I get them? I'm going to be changing to a Pertronix Electronic Ignition conversion kit. I would like a stock looking set of spark plug wires, but I want a good performing set of wires too. Are the cloth wires good? As far as the plugs go, it has a stock carb and motor.
Why change to electronic ignition? As far as original looking plug wires, give Brillmans a call. They are the best you can get. Whats the tractor used for? That will determine the plugs you want. Some like Autolite, some like Champion. I use Autolite 386 for distributor ignitions.
With electronic ignition, it's a set it and forget it deal...not so much with points. I will be using the tractor for antique pulling.
