Last weekend I bought the Loboy 184 tractor that I had posted about. Over unit is in good shape. Tractor started right up when I hit the switch. Had it started several times last week as I moved it around for some maintenance stuff and playing with it. Went to start it tonight and its dead - just a faint click at the starter sometimes. No lights either. First though was dead battery. Got out the meter - battery tests find at over 12 volts. However no voltage at the coil. I know I've got ground as I was able to turn starter by jumping from battery to starter. Appears to be a switch problem or something from battery to switch. Are these tractors known for any type of problem like this? Can a switch go bad and not have output on any terminal. Maybe the problem is no power to the switch to start with. I've got a wiring diagram in my I & T manual I bought. Looks simple enough. There are no safety switches on the machine to mess up. Tomorrow I will try to get into the switch and try some testing on the switch. I was looking forward to trying it on the lawn tomorrow to see what it will do. Should be fun working inside a small tractor like this.
