Each brake pedal operates a master cylinder under the dash, hydraulic lines activate the wet disk brakes inside the axle housings.
If the brakes don't work it's usually because they got air in them. You can bleed them with the bleeder screws on eash axle side (under fuel tank)
There are lots of posts on YT on how to do this.
