ken house
ring gear on farmall cub differential has some missing teeth. removed the axles and removed differential. had trouble getting differential out of case. tried to pull carrier bearing, but busted it and had to break it out. i suppose that i did not have the correct bearing puller. differential would not come out until i removed all of the bearing. i plan to remove differential from another cub . i would like to save the bearings, if possible. a suggestion would be received warmly.
