660 Clutch Pressure Plate Question
labman98
I am putting my 660 LP back together from repairing the TA. Before I took it apart I went thru the adjustments of TA and clutch and my pedal to frame distance was about 1.5" and book has .75 - 1.0". I"m almost to end of adjustment on rod too. Is this a sign of a worn pressure plate?
The other half of this is I have the heights for the pressure plate but is it measured in free state or bolted up? Book does not specify.
Thanks-Matt
your free play adjustment is the very first thing you do. 3/4 - 1" is good. then you follow the book and go through the rest of adjustments.
sure funny you wouldn't check the main clutch when tractor is split. kind of a pretty much standard procedure.
