HM221 corn planter
Oldiron29
Can anyone come up with a picture of the rear hydraulic cylinder mount bracket on a HM221 2 row corn planter. Would be the bracket that mounts cylinder to frame rail just in front of the clutch housing. much thanks oldiron29
Rob, From what I see the cultivator bracket goes from the tube to the hand adjuster. so no the bracket is not the same. I have a set of cultivators on another H to look at. oldiron29
UP DATE!!!
Tures out that the cultivator brackets from the late models work for the planter. I have found a pair in the barn so I am good to go. Thanks for the replys. oldiron29
Good ! I wondered if that was the case because some of that stuff is listed separate in the one old parts manual I have so thought it might be shared between different quick attach implements.
if you still need some help I have a HM221 planter with all
parts and can send you pics. I leave cylinders attached and
mounting bracket has l shaped holder for cylinder when implements are not mounted. The mounting brackets and cylinders work on HM220, 221, 222 and HM 250 cultivators.
Its easier to leave left side on due to delayed lift for my HM250,
HM 221. Owners manuals are very informative but not so clear
until you have mounted a time or two. Good luck.
