farmall c welds on front end.
dewy
looked at 3 DIFFERENT tractos. 2 out of 3 had weld jobs on right
front..where front end bolts on..whats causing issue..and is that
common problem.thanks dewy
That was the weakest point , severe use or abuse would show there , no frame to help support the weight .
Kub6040 is correct. A frameless tractor's strength is compromised where the bolster attaches to the engine block. Hitting solid objects, or ditches will snap them where they are weakest. (the engine block). Loaders with poor load distribution put lifting stress on the engine to torque tube connection. They are tough, but accidents and abuse do break them. Jim
My brother was mowing 1st crop hay with an almost new Super c, first round hit a wash out in tall bromegrass and broke the frt end completely off.
Dad traded it in on another one.
