mrl from ohio
New User
I have had years of charging problems with my super A Farmall, great little mowing machine when it works. The second regulator this year appears to have failed. I get 9V+ from generator when the F terminal is grounded. The generator is a 3 brush,I am told the regulator intended for 2 brush will not work and that i need a cut out and resistor controller for the generator. Adding up the cost of parts i"m told are needed to make this generator work, I"m nearly to the cost of converting to 12 volt alternator. Can this generator be made to work cost effectively, or is 12 volt conversion the most logical way to go?
thanks
mike
thanks
mike
