350U brake/clutch shaft to clutch pedal ??
Duner Wi
My clutch pedal leans to the side so much I can not put the rubber dust brake grommet on .
Does the clutch pedal have a bushing in it?
I suppose I will have to make a new shaft unless there is another fix.
I looked in the online parts and can not find a bushing for clutch pedal. Can find very little in the archives.
I don't know why you couldn't find anything. This very question comes up weekly.
There is no bushing. Everything is worn. Typical repair is to get a machine shop to bore out the pedal and make you a bushing if the shaft isn't too bad, or both a bushing and a new shaft if the shaft is also egg-shaped.
Mkirsch has hit it. Machining down the original shaft till round and making the bushing to fit that works. Put a grease fitting on the bushing to allow lubrication. Jim
My search in classic view was
350U brake shaft and second search was 350U clutch shaft.
I got 5 and 9 hits.
Search for brake shaft and you got many hits but I wanted 350U specific. Thanks for the replies.
