I own an International 184 tractor and the PTO clutch is starting to make an awful noise and I am afraid I will have to replace it.
I previously did replace that same clutch back in 1985 and the part number used to order the clutch at the time was 126209C91. According to my receipt, part number 72830C91 was ordered at the same time, I believe that is a bearing needed when replacing the PTO clutch.
I am now unable to locate one of these clutch assembly, does anyone knows if they are still manufactured or if there is a substitute part number?
The drive shaft going into the clutch wobbles quite a bit, this lead me to believe there is probable a defective bearing in the clutch, anyone ever had this problem?
Million thanks
Pierre G. Joly
Canada
Million thanks
Pierre G. Joly
Canada
