Spin out rim removal
Pmer
Looking for any tips and tricks to remove a rusty 6 bar rim from a Farmall 350. And install the new one.
I have the nuts loose and the tube and tire off. Seems like a tough job so far and having some trouble moving the bolts in towards the center and off of the lugs.
Had the same issue. Heated the cast wheel to get the 6 bolts out after getting the rim off. After getting the bolts out, cleaned up the bolts and cast wheel. Then anti-seized the parts on re-assembly. The dirt settles in them over the years making things difficult.
