homebre973
I have an IH 340 Utility gas tractor that overheats after 45 minutes to an hour. I know very little (nothing) about the cooling system. My guess is that it might be clogged and I would like to drain or flush it. What would be the best method? I do not know if there is an outflow valve or just a lower hose I can remove. Since the hose and radiator are quite old, I am hesitant to do anything that might need me to replace the radiator at present. What would be the safest course of action, and is the lower hose easily replaceable if it needs to be taken off? Is there a drain valve? Thanks
