have a farmall cub that has teeth missing off of ring gear, n the differential. have a parts cub that i may be able to use for parts.
1) i could remove final drives and remove and replace the differential
2) i could split the cub at the rear of the motor and replace all the rear of tractor
3) i could split the cub at the front of the transmission and replace the rear of the tractor.
recommendations?
recommendations?
